Salut, je suis Alessandro
- Véhicule N° 1 : Citroen B14G
Salut, je me presente, je suis Alessandro et je suis italien.
Excuse moi por mon francaise d'ecole.... I prefere write in english if isn't a problem for you....
I'm an owner of Citroen B14G year 1927 that I'm finishing to restore and I need your help!
Now I search in the forum if I can found that I need, in alternative I ask you what parts I need to fix....
Thanks!
Thanks!
Re: Salut, je suis Alessandro
Bongiorno Alessandro
Would you write the list of spare parts that you need ?
We 'll try to help you !
Please to show your car in fotos !
Bonjour Berjac,
the parts that I needs are :
- tableau de bord (I have one, but is modified and not in good condition)
- moteur d'essuie-glaces
- coffre arriere
- carburateur et filtre à air (I have the original, I've revised it but doesn't work fine..... now I've sustituted them with a modern carburator temporarily)
- régulateur de tension
- poignée du démarreur
Thank you very much for the help
- coffre arriere
[quote="AlexTomas"]
- tableau de bord ..............[/quote]
foto, please
[quote="AlexTomas"]
- moteur d'essuie-glaces.......6 volts,[/quote]
in the market, but it is difficult to test them
[quote="AlexTomas"]
- coffre arriere.................[/quote]
difficult to find because it is specific, but narrow with way arounr the wheel-support in the back
[quote="AlexTomas"]
- carburateur et filtre à air (I have the original..[/quote]
please foto
[quote="AlexTomas"]
- poignée du démarreur........[/quote]
button to push ?
foto, please
[quote="AlexTomas"]
[quote="AlexTomas"]
[quote="AlexTomas"]
please foto
[quote="AlexTomas"]
button to push ?
I need tableau like this : http://docauto.perso.sfr.fr/Images/tableau_de_bord.JPG" onclick="window.open(this.href);return false;
The coffre like this : http://photos.lesanciennes.com/cache/9/ ... 667963.jpg" onclick="window.open(this.href);return false;
or this (better) : http://www.toutvendre.fr/Ancienne-MALLE ... 42677L.jpg" onclick="window.open(this.href);return false;
However I think to build one new....
The regulateur and carburateur are rimmed with red in the picture above.... I miss the air filter
Bonjour Allessandro, tu peux t’inscrire sur le forum de la 10hp qui parle de la B14.
http://www.citroen10hp.com/phpBB3/" onclick="window.open(this.href);return false;
